Ir para o conteúdo principal
Samsung Galaxy S Vibrant Camera Lens Replacement
O que você precisa
  1. Samsung Galaxy S Vibrant Camera Lens Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy S Vibrant Camera Lens Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy S Vibrant Camera Lens Replacement, Battery: passo 1, imagem 3 %32
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Camera Lens Replacement: passo 2, imagem 1 %32 Samsung Galaxy S Vibrant Camera Lens Replacement: passo 2, imagem 2 %32
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Camera Lens Replacement, Midframe: passo 3, imagem 1 %32
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Camera Lens Replacement: passo 4, imagem 1 %32
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Camera Lens Replacement: passo 5, imagem 1 %32 Samsung Galaxy S Vibrant Camera Lens Replacement: passo 5, imagem 2 %32 Samsung Galaxy S Vibrant Camera Lens Replacement: passo 5, imagem 3 %32
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Camera Lens Replacement: passo 6, imagem 1 %32 Samsung Galaxy S Vibrant Camera Lens Replacement: passo 6, imagem 2 %32
    • Slide the SD card out of its slot.
  7. Samsung Galaxy S Vibrant Camera Lens Replacement, Camera Lens: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the ribbon cable and camera lens by tugging gently at the base of the ribbon cable either by pinching with fingers or with the Tweezers.
    • Only use the pinching method when the camera lens is already broken so as to avoid damage.
Conclusão
Taylor Catlin
Membro desde: 01/15/13
79 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 18-37, Regan Winter 2013 Membro de Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,479
