Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Samsung Galaxy S III SIM Card Replacement
O que você precisa
  1. Samsung Galaxy S III SIM Card Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement, Rear Case: passo 1, imagem 2 %32
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III SIM Card Replacement: passo 2, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement: passo 2, imagem 2 %32
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III SIM Card Replacement: passo 3, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement: passo 3, imagem 2 %32
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III SIM Card Replacement: passo 4, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement: passo 4, imagem 2 %32
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III SIM Card Replacement: passo 5, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement: passo 5, imagem 2 %32
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III SIM Card Replacement, Battery: passo 6, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement, Battery: passo 6, imagem 2 %32
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III SIM Card Replacement: passo 7, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement: passo 7, imagem 2 %32
    • Remove the battery.
  8. Samsung Galaxy S III SIM Card Replacement, SIM Card: passo 8, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement, SIM Card: passo 8, imagem 2 %32 Samsung Galaxy S III SIM Card Replacement, SIM Card: passo 8, imagem 3 %32
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III SIM Card Replacement: passo 9, imagem 1 %32 Samsung Galaxy S III SIM Card Replacement: passo 9, imagem 2 %32 Samsung Galaxy S III SIM Card Replacement: passo 9, imagem 3 %32
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
Conclusão
41 outras pessoas executaram este guia.
3 comentários
My Samsung Galaxy S III does not seem to have a sim card. I bought it through Sprint around 2011 time frame. Do you know if it has an internal sim card that can not be replaced?
Joe - Responder
Sprint and Verizon are CDMA (embedded SIM) while AT&T and T-Mobile is GSM.
J Fors -
i was trying to find the sims card and insted i pulled the slot loose from the phone can it be fixed or replaced
sylviahinkle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 41
Duração total: 87,448
