Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
Pry along the top right side, and continue prying down the right side of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
90 outras pessoas executaram este guia.
3 comentários
Do I have to wait after replacing it or can I use my phone right away? If so how long
