Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Before any work can be done, on the inside of the phone, we need an access point. This is achieved by removing the rear cover of the phone. This plate protects the battery, media card, and SIM card from being exposed or damaged from common use of the phone.
O que você precisa
To remove the rear cover, locate the tab indicated by the red outline.
Using your fingernail, gently pry the rear cover.
