Ir para o conteúdo principal
Samsung Galaxy S II T989 Media Card Replacement
  1. Samsung Galaxy S II T989 Media Card Replacement, Rear Cover: passo 1, imagem 1 %32 Samsung Galaxy S II T989 Media Card Replacement, Rear Cover: passo 1, imagem 2 %32 Samsung Galaxy S II T989 Media Card Replacement, Rear Cover: passo 1, imagem 3 %32
    • To remove the rear cover, locate the tab indicated by the red outline.
    • Using your fingernail, gently pry the rear cover.
  2. Samsung Galaxy S II T989 Media Card Replacement, Media Card: passo 2, imagem 1 %32 Samsung Galaxy S II T989 Media Card Replacement, Media Card: passo 2, imagem 2 %32 Samsung Galaxy S II T989 Media Card Replacement, Media Card: passo 2, imagem 3 %32
    • The media card is found inside the area indicated with the red rectangle. The card itself is small and black making it hard to easily see.
    • After locating the card, gently use your fingers to slide the card to the right, until the card is no longer in contact with the metal.
Conclusão
Uma outra pessoa concluiu este guia.
Joshua King
Membro desde: 03/26/14
1.378 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 1-5, Benson Spring 2014 Membro de Clemson, Team 1-5, Benson Spring 2014
CLEM-BENSON-S14S1G5
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 488
