Ir para o conteúdo principal
Samsung Galaxy S II Screen Replacement
O que você precisa
  1. Samsung Galaxy S II Screen Replacement, Remove back cover: passo 1, imagem 1 %32
    • Gently remove the back cover starting from the slot given on the right side.
  2. Samsung Galaxy S II Screen Replacement, Remove battery: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the battery from the slot.
    • Carefully place the battery away from some hot object or fire.
  3. Samsung Galaxy S II Screen Replacement, Remove back case screws: passo 3, imagem 1 %32
    • Use a magnetic philips #0 head screw driver to open the 7 x 1/16 in (1.6 mm) philips head screws shown in the image.
    • Place the screws carefully in a box.
  4. Samsung Galaxy S II Screen Replacement: passo 4, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 4, imagem 2 %32 Samsung Galaxy S II Screen Replacement: passo 4, imagem 3 %32
    • Gently unlock the snap locks starting from the top left corner and progressing along the perimeter to remove the back case.
    • To unlock the snaps, apply force close to the snap in order to avoid cracking of the plastic cover.
    • Remove the plastic cover carefully and place on the white paper.
  5. Samsung Galaxy S II Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 5, imagem 2 %32
    • Use a screwdriver or another pointed tool to disconnect the screen connector.
    • Lift the cable out of the slot.
    • Gently handle the cable to avoid damage to the cable or the connector.
  6. Samsung Galaxy S II Screen Replacement: passo 6, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 6, imagem 2 %32
    • Remove the connector for the speaker and audio jack carefully.
    • Gently lift the cable to avoid damage to the cable or the connector.
  7. Samsung Galaxy S II Screen Replacement: passo 7, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 7, imagem 2 %32 Samsung Galaxy S II Screen Replacement: passo 7, imagem 3 %32
    • Use a screwdriver to gently lift the speaker which is fixed to the base with double side tape.
    • Gently lift the earpiece using a flat screwdriver.
  8. Samsung Galaxy S II Screen Replacement: passo 8, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 8, imagem 2 %32 Samsung Galaxy S II Screen Replacement: passo 8, imagem 3 %32
    • Unplug the secondary camera connector carefully and lift the cable.
    • Then unplug the connector that receives the input from the screen.
    • Remove the connection for the charging port using a screw driver.
    • Handle carefully to avoid tearing off the cable.
  9. Samsung Galaxy S II Screen Replacement: passo 9, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 9, imagem 2 %32
    • Remove the two 1.6 mm black head screws using the Phillips #00 screwdriver.
  10. Samsung Galaxy S II Screen Replacement: passo 10, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 10, imagem 2 %32
    • Disconnect the antennae from both the ends by removing the connections using flat screwdriver.
    • Carefully pull out the antennae cable from the slot.
  11. Samsung Galaxy S II Screen Replacement: passo 11, imagem 1 %32 Samsung Galaxy S II Screen Replacement: passo 11, imagem 2 %32
    • Gently peel off the power button fixed with double adhesive tape.
    • Carefully lift the button out of the slot.
    • Try to keep the double side tape on the button and handle the cable carefully to avoid tearing the ribbon.
  12. Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: passo 12, imagem 1 %32 Samsung Galaxy S II Screen Replacement, Disassemble volume up/down button: passo 12, imagem 2 %32
    • Repeat the same procedure from step 15 to remove the volume up down button.
  13. Samsung Galaxy S II Screen Replacement, Remove main board: passo 13, imagem 1 %32 Samsung Galaxy S II Screen Replacement, Remove main board: passo 13, imagem 2 %32
    • Now the main board is free. Carefully lift it up and place on the workbench gently.
  14. Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: passo 14, imagem 1 %32 Samsung Galaxy S II Screen Replacement, Lift charging port connecting cable: passo 14, imagem 2 %32
    • Peel off the ribbon cable connecting the charging port and microphone by hand.
  15. Samsung Galaxy S II Screen Replacement, Unscrew charging module: passo 15, imagem 1 %32
    • Remove the two 2.0 mm screws using the Phillips #0 screwdriver.
  16. Samsung Galaxy S II Screen Replacement, Disassemble charging port module: passo 16, imagem 1 %32 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: passo 16, imagem 2 %32 Samsung Galaxy S II Screen Replacement, Disassemble charging port module: passo 16, imagem 3 %32
    • Lift the microphone gently.
    • Lift the board out from the metal casing and place on the workbench.
  17. Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: passo 17, imagem 1 %32 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: passo 17, imagem 2 %32 Samsung Galaxy S II Screen Replacement, Remove screen and replace with new screen: passo 17, imagem 3 %32
    • Finally push the screen out applying force through the screwdriver at the highlighted locations.
    • Take out the screen, clean the remaining double side tape and adhesive.
    • Install the new screen and follow the same steps in reverse order to re assemble the phone.
Conclusão
3 outras pessoas executaram este guia.
Bader
Membro desde: 04/16/20
337 Reputação
Autoria de 1 guia
Um comentário
My Samsung Galaxy s2 is an AT&T phone
Anthony Godoy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 56
Duração total: 1,921
