Ir para o conteúdo principal
Samsung Galaxy S Blaze Volume Rocker Replacement
O que você precisa
  1. Samsung Galaxy S Blaze Volume Rocker  Replacement, Volume Rocker: passo 1, imagem 1 %32
    • Start by removing the back plate to expose the battery by pulling the back and front plates apart.
  2. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 2, imagem 1 %32
    • Remove the battery from the device and set aside.
  3. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 3, imagem 1 %32 Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 3, imagem 2 %32
    • Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 4, imagem 1 %32
    • Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 5, imagem 1 %32 Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 5, imagem 2 %32
    • The volume rocker is held into the frame by two small prongs.
    • Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
    • The prongs on the volume rocker look like this.
Conclusão
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Uma outra pessoa concluiu este guia.
Jake Best
Membro desde: 03/05/15
261 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 303
