Ir para o conteúdo principal
Samsung Galaxy S Blaze SD Card Slot Cover Replacement
O que você precisa
  1. Samsung Galaxy S Blaze SD Card Slot Cover Replacement, SD Card Slot Cover: passo 1, imagem 1 %32
    • Make sure the device is powered off and not plugged into a power source.
    • Remove the back plate to reveal the battery.
  2. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: passo 2, imagem 1 %32
    • Use a spudger or your fingers to remove the battery from the phone.
  3. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: passo 3, imagem 1 %32 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws from the device frame.
  4. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: passo 4, imagem 1 %32
    • Use the blue plastic opening tool to gently pry the frame off the phone.
    • Work around the phone with the blue plastic opening tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: passo 5, imagem 1 %32 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: passo 5, imagem 2 %32
    • The SD cover is held in place on the frame by a small tab.
    • Unhook the tab of the SD card slot cover from the frame of the device.
    • This is what the tab of the SD card slot cover looks like.
Conclusão
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 outras pessoas executaram este guia.
Rene Bolanos
Membro desde: 03/05/15
435 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 336
