Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Use a flat tool to pry the two plastic cases apart The latches are very strong, so don't be afraid to use force
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  5. Locate the missing button slot Place in replacement button, and close the plastic housing around it The button should be fully functional now, repeat past steps to reassemble the phone
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
Conclusão
Dustin
Membro desde: 12-03-2014
966 reputação
5 Guias de autoria
Please can someone help me with samsung t769 power way on the board ?
Nyawu Ebenezer - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Todo: 1,056
