Ir para o conteúdo principal
Samsung Galaxy S Blaze Motherboard Replacement
O que você precisa
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: passo 3, imagem 1 %32 Samsung Galaxy S Blaze Motherboard Replacement: passo 3, imagem 2 %32
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: passo 4, imagem 1 %32
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy S Blaze Motherboard Replacement: passo 5, imagem 2 %32 Samsung Galaxy S Blaze Motherboard Replacement: passo 5, imagem 3 %32
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: passo 6, imagem 1 %32
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
Conclusão
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 outras pessoas executaram este guia.
Rene Bolanos
Membro desde: 03/05/15
435 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 823
