Ir para o conteúdo principal
Samsung Galaxy S Blaze Display Assembly Replacement
O que você precisa
  1. Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: passo 1, imagem 1 %32 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: passo 1, imagem 2 %32 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: passo 1, imagem 3 %32
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Samsung Galaxy S Blaze Display Assembly Replacement: passo 2, imagem 1 %32
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Samsung Galaxy S Blaze Display Assembly Replacement: passo 3, imagem 1 %32 Samsung Galaxy S Blaze Display Assembly Replacement: passo 3, imagem 2 %32
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  4. Samsung Galaxy S Blaze Display Assembly Replacement: passo 4, imagem 1 %32 Samsung Galaxy S Blaze Display Assembly Replacement: passo 4, imagem 2 %32 Samsung Galaxy S Blaze Display Assembly Replacement: passo 4, imagem 3 %32
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
  5. Samsung Galaxy S Blaze Display Assembly Replacement, Display Assembly: passo 5, imagem 1 %32
    • Gently remove the 2 ribbon cables as shown.
    • Connect the new screen to the main motherboard just the same way it was connected before.
    • Be careful not to crimp or bend the ribbon cables, as this will ruin the replacement.
Conclusão
Dustin
Membro desde: 03/12/14
1.213 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 1,170
