Ir para o conteúdo principal
Samsung Galaxy R Headphone Jack Replacement
O que você precisa
  1. Samsung Galaxy R Headphone Jack Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy R Headphone Jack Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy R Headphone Jack Replacement, Rear Case: passo 1, imagem 3 %32
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Headphone Jack Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy R Headphone Jack Replacement, Battery: passo 2, imagem 2 %32 Samsung Galaxy R Headphone Jack Replacement, Battery: passo 2, imagem 3 %32
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Headphone Jack Replacement, Screws: passo 3, imagem 1 %32 Samsung Galaxy R Headphone Jack Replacement, Screws: passo 3, imagem 2 %32
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: passo 4, imagem 1 %32 Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: passo 4, imagem 2 %32 Samsung Galaxy R Headphone Jack Replacement, Headphone Jack: passo 4, imagem 3 %32
    • The headphone jack is located near the top left side of the motherboard.
    • To remove the headphone jack, gently pull on the area indicated in red until it detaches from the motherboard.
Conclusão
4 outras pessoas executaram este guia.
Keon Horahan
Membro desde: 10/13/14
841 Reputação
Autoria de 6 guias
Equipe
Clemson, Team 3-3, Benson Fall 2014 Membro de Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 1,377
