Ir para o conteúdo principal
Samsung Galaxy Prevail Touch Screen Replacement
O que você precisa
  1. Samsung Galaxy Prevail Touch Screen Replacement, Touch Screen: passo 1, imagem 1 %32
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
    Pergunte ao FixBot
  2. Samsung Galaxy Prevail Touch Screen Replacement: passo 2, imagem 1 %32
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
    Pergunte ao FixBot
  3. Samsung Galaxy Prevail Touch Screen Replacement: passo 3, imagem 1 %32
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
    Pergunte ao FixBot
  4. Samsung Galaxy Prevail Touch Screen Replacement: passo 4, imagem 1 %32
    • Using the black spudger, carefully unhinge and pry the secondary rear panel , which houses the camera lens and speaker.
    • The metal trim of the headphone jack may come loose during this process.
    Pergunte ao FixBot
  5. Samsung Galaxy Prevail Touch Screen Replacement: passo 5, imagem 1 %32
    • Using the spudger, gently pry upward on the motherboard by the right side.
    • Motherboard is connected to shield plate with ribbon cable.
    Pergunte ao FixBot
  6. Samsung Galaxy Prevail Touch Screen Replacement: passo 6, imagem 1 %32
    • Using a spudger, carefully unhinge the gray shield plate by lifting upwards on the right side.
    • The shield plate will not be fully removed, it is attached to the front panel with a ribbon cable.
    Pergunte ao FixBot
  7. Samsung Galaxy Prevail Touch Screen Replacement: passo 7, imagem 1 %32
    • Using the spudger lift up the LCD screen and replace with the new screen.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 17-6, Blackwell Fall 2016 Membro de USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 46
Ao todo: 1,046
