Ir para o conteúdo principal
Samsung Galaxy Prevail Rear Camera Lens Replacement
O que você precisa
  1. Samsung Galaxy Prevail Rear Camera Lens Replacement, Rear Camera Lens: passo 1, imagem 1 %32
    • Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
  2. Samsung Galaxy Prevail Rear Camera Lens Replacement: passo 2, imagem 1 %32
    • Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
  3. Samsung Galaxy Prevail Rear Camera Lens Replacement: passo 3, imagem 1 %32
    • Remove the (6) 4mm screws using a Phillips #00 screwdriver.
  4. Samsung Galaxy Prevail Rear Camera Lens Replacement: passo 4, imagem 1 %32
    • Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
    • The secondary rear panel houses the camera lens and speaker assembly,
    • The metal trim of the headphone jack may come loose during this process.
  5. Samsung Galaxy Prevail Rear Camera Lens Replacement: passo 5, imagem 1 %32
    • Replace the secondary rear panel which has the camera lens attached.
Conclusão
Ricardo Zuloaga
Membro desde: 09/15/16
525 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 17-6, Blackwell Fall 2016 Membro de USF Tampa, Team 17-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 289
