Ir para o conteúdo principal
Samsung Galaxy Prevail 2 Vibrator Replacement
O que você precisa
  1. Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: passo 1, imagem 1 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: passo 1, imagem 2 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Removing Back Casing: passo 1, imagem 3 %32
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: passo 2, imagem 1 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: passo 2, imagem 2 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Battery: passo 2, imagem 3 %32
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: passo 3, imagem 1 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Remove Screws: passo 3, imagem 2 %32
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: passo 4, imagem 1 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: passo 4, imagem 2 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Pry Off Back of Phone: passo 4, imagem 3 %32
    • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone.
  5. Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: passo 5, imagem 1 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: passo 5, imagem 2 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Open the Motherboard: passo 5, imagem 3 %32
    • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: passo 6, imagem 1 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: passo 6, imagem 2 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Motherboard: passo 6, imagem 3 %32
    • With plastic prying tool, lift the flap up to divide the motherboard.
    • This will make it easier to detach the internal battery.
  7. Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: passo 7, imagem 1 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: passo 7, imagem 2 %32 Samsung Galaxy Prevail 2 Vibrator Replacement, Locate and Release Vibration Motor: passo 7, imagem 3 %32
    • With plastic prying tool, lift up the vibration motor.
  8. Samsung Galaxy Prevail 2 Vibrator Replacement, Detach Vibration Motor: passo 8, imagem 1 %32
    • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
Conclusão
5 outras pessoas executaram este guia.
Garrett Bowleg
Membro desde: 10/08/14
469 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-4, Leahy Fall 2014 Membro de USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,013
