Ir para o conteúdo principal
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: passo 1, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: passo 1, imagem 2 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: passo 1, imagem 3 %32
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: passo 2, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: passo 2, imagem 2 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: passo 2, imagem 3 %32
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: passo 3, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: passo 3, imagem 2 %32
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: passo 4, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: passo 4, imagem 2 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: passo 4, imagem 3 %32
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: passo 5, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: passo 5, imagem 2 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: passo 5, imagem 3 %32
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: passo 6, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: passo 6, imagem 2 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: passo 6, imagem 3 %32
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: passo 7, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: passo 7, imagem 2 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: passo 7, imagem 3 %32
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: passo 8, imagem 1 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: passo 8, imagem 2 %32 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: passo 8, imagem 3 %32
    • Carefully lift and remove the camera from its position.
Conclusão
8 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 14-4, Leahy Fall 2014 Membro de USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 1,399
