Introdução
This guide will show you how to locate and replace the camera for the Samsung Galaxy Prevail 2. No background information is required.
O que você precisa
Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
Push the motherboard out using your thumbs as shown
With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
8 outras pessoas executaram este guia.
