Ir para o conteúdo principal
Samsung Galaxy Prevail 2 Home Button Replacement
O que você precisa
  1. Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: passo 1, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: passo 1, imagem 2 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Removing Back Casing: passo 1, imagem 3 %32
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: passo 2, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: passo 2, imagem 2 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Battery: passo 2, imagem 3 %32
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: passo 3, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Screws: passo 3, imagem 2 %32
    • Unscrew all of the screws.
    • Be sure to set aside in a safe place.
  4. Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: passo 4, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: passo 4, imagem 2 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Pry Off Back of Phone: passo 4, imagem 3 %32
    • Insert the plastic opening tool between the silver frame and the white face of the phone to pry off the front face.
    • Make sure to pry around the entire frame to loosen it before proceeding.
    • Use your thumbs to separate the motherboard from the back of the phone
  5. Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: passo 5, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: passo 5, imagem 2 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Open Up the Motherboard: passo 5, imagem 3 %32
    • With the plastic opening tool, lift up the flap to to fully open the motherboard.
  6. Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: passo 6, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: passo 6, imagem 2 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Detach Motherboard: passo 6, imagem 3 %32
    • With the plastic opening tool, lift the second flap up.
  7. Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: passo 7, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Locate Home Button: passo 7, imagem 2 %32
    • Choose the motherboard side that contains the home button, as shown in the image.
  8. Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: passo 8, imagem 1 %32 Samsung Galaxy Prevail 2 Home Button Replacement, Remove Home Button: passo 8, imagem 2 %32
    • Use the plastic opening tool to push the home button out.
    • Push the button from the face of the phone inwards as indicated in the first image.
Conclusão
6 outras pessoas executaram este guia.
Garrett Bowleg
Membro desde: 10/08/14
469 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-4, Leahy Fall 2014 Membro de USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 2,073
