Ir para o conteúdo principal
Samsung Galaxy Prevail 2 Battery Replacement
O que você precisa
  1. Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: passo 1, imagem 1 %32 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: passo 1, imagem 2 %32 Samsung Galaxy Prevail 2 Battery Replacement, Removing Back Casing: passo 1, imagem 3 %32
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: passo 2, imagem 1 %32 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: passo 2, imagem 2 %32 Samsung Galaxy Prevail 2 Battery Replacement, Remove Battery: passo 2, imagem 3 %32
    • Gently pull the battery out of the phone.
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 14-4, Leahy Fall 2014 Membro de USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
Membros da 4
Autoria de 5 guias
3 comentários
I just replaced the battery about a month ago after turning phone off and the turned back on it stuck on screen with samsung and the other lights stayed on
lindabuhl5729 - Responder
Mine doing the same
Chuck Slagel - Responder
"To reassemble your device, follow these instructions in reverse order" seriously?! I mean even an idiot should know that!
illy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 1,892
