Introdução
If you want or need access to the inner parts of your device, you'll need to start by removing the battery casing. Removing the battery casing requires patience because it sits firmly in place. Take your time and carefully work the casing off by prying around the edge.
O que você precisa
Use your finger to press in the battery cover tab on the upper right hand corner of the back of the device.
Pry the battery cover off the device by pressing in and lifting up.
5 outras pessoas executaram este guia.
