Introdução
The display is a 5 inch in size and with a resolution of 720x1280 pixels. And it is a touchscreen.
O que você precisa
Use a plastic pry tool to lift the front-facing camera from its housing.
Using a Phillips #00 screwdriver, remove the screw securing the rear-facing camera.
Once the logic board is stripped of the cameras, replace the logic board.
Take a plastic stick to insert into the headphone jack to lift part of the housing.
Once that's complete place the part aside.
9 outras pessoas executaram este guia.
