Ir para o conteúdo principal
Samsung Galaxy Note5 Display Replacement
O que você precisa
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: passo 1, imagem 1 %32
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: passo 2, imagem 1 %32
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: passo 3, imagem 1 %32
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: passo 4, imagem 1 %32
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
    Ouch Didn't get it hot enough? Hopefully you ordered the back plate too, luckily they ain't too expensive
    Tuan Bui - Responder
  5. Samsung Galaxy Note5 Display Replacement: passo 5, imagem 1 %32
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: passo 6, imagem 1 %32
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: passo 7, imagem 1 %32
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: passo 8, imagem 1 %32
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: passo 9, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 9, imagem 2 %32
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
    Phillips #0 in my particular case?
    Emmanuel Garcia - Responder
  10. Samsung Galaxy Note5 Display Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 10, imagem 2 %32 Samsung Galaxy Note5 Display Replacement: passo 10, imagem 3 %32
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: passo 11, imagem 1 %32
    • Loosen the two signal cable connectors.
    Not the ones at the bottom but the ones connected to the mainboard
  12. Samsung Galaxy Note5 Display Replacement: passo 12, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 12, imagem 2 %32 Samsung Galaxy Note5 Display Replacement: passo 12, imagem 3 %32
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
    There‘s a bunch more flex cables to disconnect that are not shown here. Refer to Mainboard Replacement Guide for further details.
  13. Samsung Galaxy Note5 Display Replacement: passo 13, imagem 1 %32
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: passo 14, imagem 1 %32
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: passo 15, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 15, imagem 2 %32 Samsung Galaxy Note5 Display Replacement: passo 15, imagem 3 %32
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
    I use a curled plastic guitar pick to get underneath the battery. It’s a really bad idea to use metal tools for this.
    Bryan Rought - Responder
    +1 here, I used the plastic spudger, still a bit sketchy without heating. i guess a little bit of heat from the screen side would help soften the adhesive
    Jimmy Beaudoin -
  16. Samsung Galaxy Note5 Display Replacement: passo 16, imagem 1 %32
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: passo 17, imagem 1 %32
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: passo 18, imagem 1 %32
    • The display is now removed.
Conclusão
37 outras pessoas executaram este guia.
Alexander Laucius
Membro desde: 04/19/18
1.536 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S25-G17, Maness Spring 2018 Membro de Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
Membros da 4
Autoria de 5 guias
6 comentários
Worked like a charm
Ronald Sapp - Responder
How does one bond everything back together?
lcplthomasc - Responder
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina -
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
Cristina -
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - Responder
You say no u hing about being careful about the switches ribbon cables or thr push button. I guess you assume that it come as part of the screen assembly. Will it doesn't. Complete moron to leave a step out of the instructions.
Dick foru - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 101
Duração total: 23,932
