Ir para o conteúdo principal
Samsung Galaxy Note5 Display Replacement
O que você precisa
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: passo 1, imagem 1 %32
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: passo 2, imagem 1 %32
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: passo 3, imagem 1 %32
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: passo 4, imagem 1 %32
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Display Replacement: passo 5, imagem 1 %32
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: passo 6, imagem 1 %32
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: passo 7, imagem 1 %32
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: passo 8, imagem 1 %32
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: passo 9, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 9, imagem 2 %32
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Display Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 10, imagem 2 %32 Samsung Galaxy Note5 Display Replacement: passo 10, imagem 3 %32
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: passo 11, imagem 1 %32
    • Loosen the two signal cable connectors.
  12. Samsung Galaxy Note5 Display Replacement: passo 12, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 12, imagem 2 %32 Samsung Galaxy Note5 Display Replacement: passo 12, imagem 3 %32
    Ferramenta utilizada neste passo:
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
  13. Samsung Galaxy Note5 Display Replacement: passo 13, imagem 1 %32
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: passo 14, imagem 1 %32
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: passo 15, imagem 1 %32 Samsung Galaxy Note5 Display Replacement: passo 15, imagem 2 %32 Samsung Galaxy Note5 Display Replacement: passo 15, imagem 3 %32
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
  16. Samsung Galaxy Note5 Display Replacement: passo 16, imagem 1 %32
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: passo 17, imagem 1 %32
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: passo 18, imagem 1 %32
    • The display is now removed.
Conclusão
41 outras pessoas executaram este guia.
Alexander Laucius
Membro desde: 04/19/18
1.662 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S25-G17, Maness Spring 2018 Membro de Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 Membros
Autoria de 6 guias
6Comentários do guia
Worked like a charm
Ronald Sapp - Responder Compartilhar
How does one bond everything back together?
lcplthomasc - Responder Compartilhar
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina - Compartilhar
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 33
Últimos 30 dias: 130
Ao todo: 26,768
