Ir para o conteúdo principal
Samsung Galaxy Note USB Board Replacement
O que você precisa
  1. Samsung Galaxy Note USB Board Replacement, Stylus: passo 1, imagem 1 %32 Samsung Galaxy Note USB Board Replacement, Stylus: passo 1, imagem 2 %32
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note USB Board Replacement, Rear Case: passo 2, imagem 1 %32 Samsung Galaxy Note USB Board Replacement, Rear Case: passo 2, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note USB Board Replacement: passo 3, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 3, imagem 2 %32
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note USB Board Replacement, Battery: passo 4, imagem 1 %32 Samsung Galaxy Note USB Board Replacement, Battery: passo 4, imagem 2 %32
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note USB Board Replacement, MicroSD Card: passo 5, imagem 1 %32 Samsung Galaxy Note USB Board Replacement, MicroSD Card: passo 5, imagem 2 %32 Samsung Galaxy Note USB Board Replacement, MicroSD Card: passo 5, imagem 3 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note USB Board Replacement: passo 6, imagem 1 %32
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note USB Board Replacement, SIM Card: passo 7, imagem 1 %32 Samsung Galaxy Note USB Board Replacement, SIM Card: passo 7, imagem 2 %32
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note USB Board Replacement: passo 8, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 8, imagem 2 %32
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note USB Board Replacement, Midframe: passo 9, imagem 1 %32
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note USB Board Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 10, imagem 2 %32
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note USB Board Replacement: passo 11, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 11, imagem 2 %32 Samsung Galaxy Note USB Board Replacement: passo 11, imagem 3 %32
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note USB Board Replacement: passo 12, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 12, imagem 2 %32 Samsung Galaxy Note USB Board Replacement: passo 12, imagem 3 %32
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note USB Board Replacement: passo 13, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 13, imagem 2 %32
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: passo 14, imagem 1 %32 Samsung Galaxy Note USB Board Replacement, Motherboard Assembly: passo 14, imagem 2 %32
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note USB Board Replacement: passo 15, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 15, imagem 2 %32 Samsung Galaxy Note USB Board Replacement: passo 15, imagem 3 %32
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note USB Board Replacement: passo 16, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 16, imagem 2 %32 Samsung Galaxy Note USB Board Replacement: passo 16, imagem 3 %32
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note USB Board Replacement: passo 17, imagem 1 %32
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note USB Board Replacement: passo 18, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 18, imagem 2 %32
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note USB Board Replacement, USB Board: passo 19, imagem 1 %32
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  20. Samsung Galaxy Note USB Board Replacement: passo 20, imagem 1 %32
    • Lift the speaker enclosure from the display assembly.
  21. Samsung Galaxy Note USB Board Replacement: passo 21, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 21, imagem 2 %32
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
  22. Samsung Galaxy Note USB Board Replacement: passo 22, imagem 1 %32 Samsung Galaxy Note USB Board Replacement: passo 22, imagem 2 %32 Samsung Galaxy Note USB Board Replacement: passo 22, imagem 3 %32
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
  23. Samsung Galaxy Note USB Board Replacement: passo 23, imagem 1 %32
    • Remove the USB board.
Conclusão
51 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
471.486 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
6 comentários
Using the Guides on online and the PDF guides made this repair easy and quick!
Joe - Responder
It's not necessary to remove the motherboard (steps 17 and 18) to complete this repair. The flat flex running to the USB board can be easily slid out from under the motherboard with the motherboard still in position. Just omit steps 17 and 18 and the rest of the procedure works fine. I've done it twice.
Phil - Responder
Where in England could I buy the USB Board part?
Craig Pyle - Responder
USB board bought off ebay. Didnt need plastic opening tools, thumb nail worked easier than expected.
john dingley - Responder
It's not the Galaxy Note GT-N7000!
costantino - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 24,487
