Ir para o conteúdo principal
Samsung Galaxy Note Pro 12.2 SD Port Replacement
O que você precisa
  1. Samsung Galaxy Note Pro 12.2 SD Port Replacement, SD Port: passo 1, imagem 1 %32
    • Turn off your device before starting your repair.
    • Carefully remove the back cover with the plastic opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 2, imagem 2 %32
    • Pop up the orange tab connected to the SD port with the plastic opening tool.
  3. Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 3, imagem 1 %32 Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 3, imagem 2 %32
    • Remove the one 3mm Phillips #00 screw connected to the SD port.
  4. Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 4, imagem 1 %32 Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 4, imagem 2 %32
    • Pop open the orange wire tab connected to the SD port with the plastic opening tool.
    • If there is tape covering your tab, remove it with the tweezers before you pop open the tab.
  5. Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 5, imagem 1 %32 Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 5, imagem 2 %32
    • Using the orange tab, pull the SD port up and away from the device.
  6. Samsung Galaxy Note Pro 12.2 SD Port Replacement: passo 6, imagem 1 %32
    • Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
    • There is a little indent below the orange tab to help get under this piece. It may be difficult to remove, push up hard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 489
