Ir para o conteúdo principal
Samsung Galaxy Note Pro 12.2 Audio Jack Replacement
O que você precisa
  1. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement, Audio Jack: passo 1, imagem 1 %32
    • Make sure that your device is powered off before starting your repair.
    • Carefully remove the back cover with the blue opening tool.
    • It is best to start with one corner and work your way around the device slowly.
  2. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 2, imagem 2 %32
    • Remove the two 3mm Phillips #00 screws securing in the white cover over the audio jack.
  3. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 3, imagem 1 %32
    • Remove the white cover over the audio jack with the plastic opening tool by pushing up on the black connecter.
  4. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 4, imagem 1 %32 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 4, imagem 2 %32
    • Remove the two 3mm Phillips #00 screws over the silver cover.
    • The silver cover is attached to the whole audio jack; do not try to pull this away by itself.
  5. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 5, imagem 1 %32 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 5, imagem 2 %32
    • Pop up the green connecter by gently pulling up.
  6. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 6, imagem 1 %32 Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 6, imagem 2 %32
    • Pull up on the circular amp with the spudger tool to release it from the device.
  7. Samsung Galaxy Note Pro 12.2 Audio Jack Replacement: passo 7, imagem 1 %32
    • Remove the whole audio jack by pulling gently up on the copper piece.
    • This component is extremely fragile.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 674
