Ir para o conteúdo principal
Samsung Galaxy Note Midframe Replacement
O que você precisa
  1. Samsung Galaxy Note Midframe Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Note Midframe Replacement, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  2. Samsung Galaxy Note Midframe Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note Midframe Replacement: passo 2, imagem 2 %32
    • Lift and remove the rear case from the phone.
  3. Samsung Galaxy Note Midframe Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Note Midframe Replacement, Battery: passo 3, imagem 2 %32
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  4. Samsung Galaxy Note Midframe Replacement, MicroSD Card: passo 4, imagem 1 %32 Samsung Galaxy Note Midframe Replacement, MicroSD Card: passo 4, imagem 2 %32 Samsung Galaxy Note Midframe Replacement, MicroSD Card: passo 4, imagem 3 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note Midframe Replacement: passo 5, imagem 1 %32
    • Remove the microSD card from its slot in the midframe.
  6. Samsung Galaxy Note Midframe Replacement, SIM Card: passo 6, imagem 1 %32 Samsung Galaxy Note Midframe Replacement, SIM Card: passo 6, imagem 2 %32
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  7. Samsung Galaxy Note Midframe Replacement: passo 7, imagem 1 %32 Samsung Galaxy Note Midframe Replacement: passo 7, imagem 2 %32
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  8. Samsung Galaxy Note Midframe Replacement, Midframe: passo 8, imagem 1 %32
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  9. Samsung Galaxy Note Midframe Replacement: passo 9, imagem 1 %32 Samsung Galaxy Note Midframe Replacement: passo 9, imagem 2 %32
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  10. Samsung Galaxy Note Midframe Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note Midframe Replacement: passo 10, imagem 2 %32 Samsung Galaxy Note Midframe Replacement: passo 10, imagem 3 %32
    • Slide the plastic opening tool down the seam.
  11. Samsung Galaxy Note Midframe Replacement: passo 11, imagem 1 %32 Samsung Galaxy Note Midframe Replacement: passo 11, imagem 2 %32 Samsung Galaxy Note Midframe Replacement: passo 11, imagem 3 %32
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  12. Samsung Galaxy Note Midframe Replacement: passo 12, imagem 1 %32 Samsung Galaxy Note Midframe Replacement: passo 12, imagem 2 %32
    • Remove the midframe from the display assembly.
Conclusão
16 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
477.233 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.685 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 87
Ao todo: 11,291
