Introdução
Use this guide to remove the back cover. This guide is a prerequisite for many other guides. You may need to remove the midframe if your need to install a new antenna, Micro USB port, headphone jack and earpiece, or replace the motherboard.
O que você precisa
Make sure the screen is face-down and the camera is opposite you.
Insert the flat end of a spudger into the phone's top right rectangular slot.
Use the spudger as a lever to pry open the back of the phone.
Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
4 outras pessoas executaram este guia.
