Ir para o conteúdo principal
Samsung Galaxy Note MicroSD Card Replacement
O que você precisa
  1. Samsung Galaxy Note MicroSD Card Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Note MicroSD Card Replacement, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  2. Samsung Galaxy Note MicroSD Card Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note MicroSD Card Replacement: passo 2, imagem 2 %32
    • Lift and remove the rear case from the phone.
  3. Samsung Galaxy Note MicroSD Card Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Note MicroSD Card Replacement, Battery: passo 3, imagem 2 %32
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  4. Samsung Galaxy Note MicroSD Card Replacement, MicroSD Card: passo 4, imagem 1 %32 Samsung Galaxy Note MicroSD Card Replacement, MicroSD Card: passo 4, imagem 2 %32 Samsung Galaxy Note MicroSD Card Replacement, MicroSD Card: passo 4, imagem 3 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note MicroSD Card Replacement: passo 5, imagem 1 %32
    • Remove the microSD card from its slot in the midframe.
Conclusão
Sam Goldheart
Membro desde: 10/18/12
471.486 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 6,513
