Ir para o conteúdo principal
Samsung Galaxy Note II Speaker Enclosure Replacement
O que você precisa
  1. Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: passo 1, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement, Stylus: passo 1, imagem 2 %32
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: passo 2, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement, Rear Case: passo 2, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 3, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 3, imagem 2 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 3, imagem 3 %32
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: passo 4, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: passo 4, imagem 2 %32 Samsung Galaxy Note II Speaker Enclosure Replacement, MicroSD Card: passo 4, imagem 3 %32
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: passo 5, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement, Battery: passo 5, imagem 2 %32
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 6, imagem 1 %32
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Speaker Enclosure Replacement, Midframe: passo 7, imagem 1 %32
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 8, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 8, imagem 2 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 8, imagem 3 %32
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 9, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 9, imagem 2 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 9, imagem 3 %32
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 10, imagem 2 %32
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 11, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 11, imagem 2 %32
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 12, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 12, imagem 2 %32
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 13, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 13, imagem 2 %32
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 14, imagem 1 %32 Samsung Galaxy Note II Speaker Enclosure Replacement: passo 14, imagem 2 %32
    • Lift the display assembly out of the midframe.
  15. Samsung Galaxy Note II Speaker Enclosure Replacement, Speaker Enclosure: passo 15, imagem 1 %32
    • Remove the 3 mm Phillips #00 screw from the speaker enclosure.
  16. Samsung Galaxy Note II Speaker Enclosure Replacement: passo 16, imagem 1 %32
    • Remove the speaker enclosure.
Conclusão
9 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.647 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.732 guias
Um comentário
This is an awesome guide! Cheers Sam. I have never done any electrical fixes before so I was a phone fixing virgin. I bought both the tools and the speaker for £5.80 on ebay, followed your guide carefully and had no problems. It was an easy process. Thanks to the confidence I had in your guide I didn’t have to go and buy a new phone so you saved me the £180 I thought I was going to have to spend!
Cheers, Nick (UK)
Nick Village - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 13,803
