Introdução
If you are unable to adjust the volume on your device, the volume switch may be faulty. Use this guide to replace the volume button in your device.
O que você precisa
Place your device flat down on a clean surface.
Use a Spudger to remove the back cover using the notch at the top left.
Quase terminado!
Conclusão
