Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The phones motherboard is the hub of all activity on the phone. It is a very important component, and is essential for the phone to operate.
O que você precisa
Power down your device and make sure that it is turned off.
Place the phone with the screen facing down on a clean flat surface.
Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
Remove the stylus from the stylus holder.
Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
Insert your spudger into the stylus socket and pry the midframe from the phone.
Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
4 outras pessoas executaram este guia.
