Ir para o conteúdo principal
Samsung Galaxy Note Edge Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Note Edge Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Power down your device and make sure that it is turned off.
    • Place the phone with the screen facing down on a clean flat surface.
  2. Samsung Galaxy Note Edge Motherboard Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 2, imagem 2 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 2, imagem 3 %32
    • Use your Supdger to remove the back cover of the phone using notch located in the top left corner of the phone.
    • Remove battery by using your Supdger on the notch located directly underneath battery location.
    • During the creation of this guide, we did not have access to a battery in our device.
  3. Samsung Galaxy Note Edge Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove the SIM Card from the SIM Card holder by gently sliding the SIM Card horizontally.
    • Remove the stylus from the stylus holder.
  4. Samsung Galaxy Note Edge Motherboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 4, imagem 2 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 4, imagem 3 %32
    • Using a Phillips #000 Screwdriver, remove the fifteen 4mm screws that secure the rear chassis.
    • Insert your spudger into the stylus socket and pry the midframe from the phone.
    • Move the spudger around edge of phone, carefully prying the midframe from the phone until midframe is entirely separated.
  5. Samsung Galaxy Note Edge Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 5, imagem 2 %32
    • With the pointed end of your spudger, disconnect the two wires (pink and white) located near the bottom of the phone.
    • Using pointed end of your dpudger, disconnect the finger print scanner cable- it is located directly above the pink and white cables.
  6. Samsung Galaxy Note Edge Motherboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 6, imagem 2 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 6, imagem 3 %32
    • Using your Spudger's pointed end, pry off the following leads that connect these parts to the logic board in the top left hand corner:
    • Front Facing Camera
    • AMOLED Display Screen
    • AMOLED Capacitive Screen
  7. Samsung Galaxy Note Edge Motherboard Replacement: passo 7, imagem 1 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 7, imagem 2 %32 Samsung Galaxy Note Edge Motherboard Replacement: passo 7, imagem 3 %32
    • At the top end, gently insert pointed end of spudger underneath the motherboard.
    • Lift the motherboard up gently. Disconnect the cable connecting the daughter board. It is attached to the underside of the motherboard.
    • Remove the motherboard from the device.
Conclusão
4 outras pessoas executaram este guia.
Matt Clark
Membro desde: 04/19/18
157 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S22-G6, Maness Spring 2018 Membro de Cal Poly, Team S22-G6, Maness Spring 2018
CPSU-MANESS-S18S22G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 25
Duração total: 3,488
