Introdução
How to change the Samsung GalaxyNote Edge / N915 screen assembly
_______Video manual_______
O que você precisa
Vídeo de Apresentação
Switch off the device.
Remove the back cover and the battery.
Remove the Memory card, the SIM card and the S Pen.
Remove the screws by using Screwdriver Phillips #00
With a plastic opening tool emove the Back Frame.
Disconnect one by one:
Coaxial antenna cable (x2)
Home Button flex cable
Display Flex cable
Stylus Sensor flex cable
Front Camera flex cable
Pry up the connector on the back of the board to release the bottom part of motherboard.
Gently remove the logic board.
I prefer to test the new spare part before install it.
Transfer the Power button / Loud speaker flex cable.
Install the mother board.
Test the display.
Check the quality of the thermal pads (if the spare part is not original).
If its necessary use the thermal pads from the old assembly.
Remove the black Phillips screw,
the the charging port plate,
disconnect the Home buttons flex cable
and the coaxial antenna cable (x2).
Use hot air and a plastic opening tool to remove the Charging Port flex assembly.
