Introdução
Your Samsung Galaxy Note Edge's battery may be dead or damaged and in need of replacement. Be wary and cautious of batteries that are leaking or damaged. Before beginning the repair guide, ensure you have the proper replacement battery- a Lithium-Ion 3000 mAh battery.
O que você precisa
Power down your device and make sure that it is turned off.
Place the phone with the screen facing down on a clean flat surface.
Um comentário
La batterie a une faible autonomie et se dégrade vite, en bombant souvent. Déjà 3 batteries remplacées sans succès. Que faire?
