Ir para o conteúdo principal
Samsung Galaxy Note 8.0 Back Cover Replacement
O que você precisa
  1. Samsung Galaxy Note 8.0 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Back Cover Replacement: passo 2, imagem 1 %32
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Back Cover Replacement: passo 3, imagem 1 %32
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
Conclusão
16 outras pessoas executaram este guia.
Joel
Membro desde: 09/23/14
1.862 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2014 Membro de USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
Membros da 4
Autoria de 16 guias
5 comentários
news flash that phone in the picture is NOT a note 8
Nic Wilson - Responder
As stated in the title, this is regarding Galaxy Note 8.0 ( 2013 ), not for Note 8 Phone.
deadyoda -
Thanks for the guide, helped me to add a QI module into my Galaxy Note 8.0
deadyoda -
Thanks for sharing this useful guide! Also, if issue is related with software, we can use unbrick guide to get it repair.
Cheers!
Deepak Gupta - Responder
Thanks for sharing this info for the basic understanding. I always wanted to do this but afraid of the consequences.
Even I sell mobile covers in my shop from Mobile Back Covers.
Really helpful for me to explain my customers.
Invite Celebrate - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Duração total: 34,082
