Introdução
The back cover is the cover to all of the inner components of the tablet. If you need to access any of those parts, you must start by removing the back cover. Alternatively, your back cover may receive wear and tear over time from use, which could result in it cracking and needing to be replaced. In either case, this guide will show you how to remove or replace the back case.
O que você precisa
16 outras pessoas executaram este guia.
4 comentários
Thanks for sharing this useful guide! Also, if issue is related with software, we can use unbrick guide to get it repair.
Cheers!
