Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Heat the back cover to melt the strong adhesive sticker underneath.
Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
If you do it hardly, you need much more heat especially the edged side.
Slipping a playing card through the gap is a good way to loosen up the adhesive.
Remove the back cover. The white stripe is the sticker.
45 outras pessoas executaram este guia.
9 comentários
will it go back on and stay on without new adhesive?
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs -
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
How do I remove the sticky part
