Ir para o conteúdo principal
Samsung Galaxy Note 5 Back Cover Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy Note 5 Back Cover Replacement, Samsung Galaxy Note 5 Back Cover Replacement: passo 1, imagem 1 %32
    • Heat the back cover to melt the strong adhesive sticker underneath.
    Pergunte ao FixBot
  2. Samsung Galaxy Note 5 Back Cover Replacement: passo 2, imagem 1 %32
    • Try to pull and open a gap between back cover and frame after heat. Insert into a guitar pick to cut the sticker.
    Pergunte ao FixBot
  3. Samsung Galaxy Note 5 Back Cover Replacement: passo 3, imagem 1 %32
    • If you do it hardly, you need much more heat especially the edged side.
    • Slipping a playing card through the gap is a good way to loosen up the adhesive.
    Pergunte ao FixBot
  4. Samsung Galaxy Note 5 Back Cover Replacement: passo 4, imagem 1 %32
    • Remove the back cover. The white stripe is the sticker.
    Pergunte ao FixBot
Conclusão
45 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.911 Reputação
Autoria de 62 guias
9Comentários do guia
What about putting the one back on?
rcf917 - Responder Compartilhar
will it go back on and stay on without new adhesive?
dfasdfjiun - Responder Compartilhar
I suggest that you take new adhesive, old adhesive is not strong enough to hold back cover.
Witrigs - Responder Compartilhar
You can check this video of put it back battery cover : https://www.youtube.com/watch?v=3HrmeVGY...
How do I remove the sticky part
Marcelino Lopez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 109
Ao todo: 109,694
