Ir para o conteúdo principal
Samsung Galaxy Note 4 Rear Facing Camera Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy Note 4 Rear Facing Camera Replacement, Rear Facing Camera: passo 1, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement, Rear Facing Camera: passo 1, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement, Rear Facing Camera: passo 1, imagem 3 %32
    • Take away the back cover and battery easily. Don't forget to remove SIM card and S Pen.
  2. Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 2, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 2, imagem 3 %32
    • Remove all 16 screws together on the back.
  3. Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 3, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 3, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 3, imagem 3 %32
    • Cut LCD screen sticker, loosen clasps around battery slot and push the whole front assembly out from middle housing.
  4. Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • We can see the motherboard now and the rear camera is connected by a connector on the back of motherboard. So we have to remove motherboard before removing rear camera.
  5. Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 5, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 5, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 5, imagem 3 %32
    • Before removing motherboard, we have to remove LCD screen. You can see more details on Samsung Galaxy Note 4 LCD screen replacement.
    • If just removing the rear camera it is not necessary to remove the LCD from the assembly. simply unscrew the one screw located on the left side of the motherboard and disconnect flex cables with a plastic spudger, keeping in mind the two connections underneath the board where the LCD connects. You run less risk of damage to the display this way.
    You do not need to remove LCD\Digitizer assembly from the bezel to replace the rear camera. Doing so is dangerous not to mention adds unnecessary time to the repair.
    Gabriel Burchfield - Responder
  6. Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 6, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 6, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 6, imagem 3 %32
    • Release connectors which connecting with motherboard.
  7. Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 7, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 7, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 7, imagem 3 %32
    • Remove the screws, you can remove the top one only. Pry up and release USB board connector on the back.
    • Finally, remove motherboard.
  8. Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 8, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 8, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Replacement: passo 8, imagem 3 %32
    • Release rear camera connector and remove it.
Conclusão
30 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
14 comentários
What is the tool, they use in step 5?
Sara Lee - Responder
Just look at the photo and Google it. "The opening tool" or HH-5A
isaactannermadsen - Responder
Hello good day! Could someone tell me what do you call these platelets circuits that have bonded to the housing samsung galaxy note 4 I circled in red the following .. images.
[img]http://i.imgur.com/2vvZ2dK.jpg?1[/img]
[img]http://i.imgur.com/ViV1TUL.jpg?1[/img]
elisangelops - Responder
What could you do if just the glass was broken on your camera lens but camera still worked?
sheets83 -
if you only have the glass broken you *MIGHT* be able to just replace the glass cover but there is a huge risk of glass and dust contamination ruining the camera anyways. I personally had this happen after replacing the glass cover and now have black splotches all over even after I tried my damnest to control for dust.
Michael Goelz -
They are antenna’s or the connectors to the antennas.
Dennis Smith -
Do i loose my information on my note 4 after these procedures and need to have a backup before i start?
Massoud - Responder
I have a 910C model. I would like to know if all models (A, C, F, U...) have the same camera inside?
Best regards
Salih - Responder
The chipset(s) would be different in each one, I would think.
Gabe -
hi guys. i was just wondering, could we replace the camera with a different one? say the Sony IMX260 camera from samsung galaxy note 7 or maybe s7 edge?
canisperosrn - Responder
just broke the screen now
mohamed.rashad1989 - Responder
How much is the camera lens?
Maru - Responder
Hi Guys! I've tried to change camera module 3 times, but it shows always error that module cannot be found.
Initial Camera is working well. I tried to put the same module for N910C
Model SM-N910C
can you tell me please how I could fixed it?
Georgy Grebeshkov - Responder
is the note 4 and note 5 camera the same..??
ravi 6662 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Duração total: 48,951
