Ir para o conteúdo principal
Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement
O que você precisa
Vídeo de Apresentação
Samsung Galaxy Note 4 Rear-facing Camera Lens Replacement
  1. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: passo 2, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: passo 2, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement, Rear Facing Camera Lens: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to pry off the rear-facing camera ring.
    • You may need to use the tweezers to run along the sides of the camera ring to loosen it.
  3. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: passo 3, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: passo 3, imagem 2 %32
    • Use a pair of tweezers to peel off the camera ring adhesive.
  4. Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: passo 4, imagem 1 %32 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: passo 4, imagem 2 %32 Samsung Galaxy Note 4 Rear Facing Camera Lens Replacement: passo 4, imagem 3 %32
    • Gently slide one tip of a pair of tweezers underneath the rear-facing camera lens.
    • Pry upwards with the tweezers and remove the camera lens.
Conclusão
16 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
2 comentários
Iam gonna order this now. Thanks for the tip. How much should I expect to pay for new lens. ????
Tommy Holmes - Responder
aliexpress or ebay from china ~$1
altomic -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 35,574
