Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Use this guide to replace the midframe on your Galaxy Note 4.
Vídeo de Apresentação
  1. Remove back cover really easily as usual. Remove back cover really easily as usual.
    • Remove back cover really easily as usual.
  2. Take away the 3200mAh battery, SIM card and S Pen. Take away the 3200mAh battery, SIM card and S Pen.
    • Take away the 3200mAh battery, SIM card and S Pen.
  3. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  4. Remove 16 screws all together. Be patient. Remove 16 screws all together. Be patient. Remove 16 screws all together. Be patient.
    • Remove 16 screws all together. Be patient.
  5. Cut the adhesive sticker along the side of middle housing. Notice: There is no need to separate the LCD screen from mid-plate. So just cut the sticker along side and get the front assembly loosen. Don't do anything else here.
    • Cut the adhesive sticker along the side of middle housing. Notice: There is no need to separate the LCD screen from mid-plate. So just cut the sticker along side and get the front assembly loosen. Don't do anything else here.
  6. Loosen the clasp around battery slot. Loosen the clasp around battery slot. Loosen the clasp around battery slot.
    • Loosen the clasp around battery slot.
  7. Push the front assembly out from middle housing with effort and separate them. Find comfortable force point to push. You can start it from top side especially left corner seen from back. Finally remove the middle housing.
    • Push the front assembly out from middle housing with effort and separate them. Find comfortable force point to push. You can start it from top side especially left corner seen from back.
    • Finally remove the middle housing.
Conclusão
15 outras pessoas concluíram este guia.
Sophia
Membro desde: 25/03/2014
42.869 Reputação
62 Guias de autoria
Terrible guide. Don't follow this unless you want to risk cracking your screen
Tyler Jones - Responder
My phone screen cracked near the menu button
Anna - Responder
adhesive sticker couldnt put back LCD. this tutorial cost me 400$
Dominik Chobo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 18,227
