Ir para o conteúdo principal
Samsung Galaxy Note 4 Headphone Jack Replacement
O que você precisa
  1. Samsung Galaxy Note 4 Headphone Jack Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Note 4 Headphone Jack Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Headphone Jack Replacement, Battery: passo 2, imagem 1 %32
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Headphone Jack Replacement, SIM Card: passo 3, imagem 1 %32 Samsung Galaxy Note 4 Headphone Jack Replacement, SIM Card: passo 3, imagem 2 %32
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  4. Samsung Galaxy Note 4 Headphone Jack Replacement, Midframe: passo 4, imagem 1 %32
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  5. Samsung Galaxy Note 4 Headphone Jack Replacement: passo 5, imagem 1 %32 Samsung Galaxy Note 4 Headphone Jack Replacement: passo 5, imagem 2 %32 Samsung Galaxy Note 4 Headphone Jack Replacement: passo 5, imagem 3 %32
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  6. Samsung Galaxy Note 4 Headphone Jack Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  7. Samsung Galaxy Note 4 Headphone Jack Replacement: passo 7, imagem 1 %32 Samsung Galaxy Note 4 Headphone Jack Replacement: passo 7, imagem 2 %32 Samsung Galaxy Note 4 Headphone Jack Replacement: passo 7, imagem 3 %32
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  8. Samsung Galaxy Note 4 Headphone Jack Replacement, Headphone Jack: passo 8, imagem 1 %32 Samsung Galaxy Note 4 Headphone Jack Replacement, Headphone Jack: passo 8, imagem 2 %32 Samsung Galaxy Note 4 Headphone Jack Replacement, Headphone Jack: passo 8, imagem 3 %32
    • Use the plastic spudger and tweezers to remove the headphone jack from the middle housing.
  9. Samsung Galaxy Note 4 Headphone Jack Replacement: passo 9, imagem 1 %32 Samsung Galaxy Note 4 Headphone Jack Replacement: passo 9, imagem 2 %32
    • Pry the headphone jack up from the midframe.
Conclusão
21 outras pessoas executaram este guia.
Derek Nola
Membro desde: 01/06/15
2.151 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 70-6, Forte Winter 2015 Membro de Cal Poly, Team 70-6, Forte Winter 2015
CPSU-FORTE-W15S70G6
4 Membros
16 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 19,885
