Ir para o conteúdo principal
Samsung Galaxy Note 4 Antenna Replacement
O que você precisa
  1. Samsung Galaxy Note 4 Antenna Replacement, Midframe: passo 1, imagem 1 %32
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  2. Samsung Galaxy Note 4 Antenna Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note 4 Antenna Replacement: passo 2, imagem 2 %32 Samsung Galaxy Note 4 Antenna Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  3. Samsung Galaxy Note 4 Antenna Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  4. Samsung Galaxy Note 4 Antenna Replacement: passo 4, imagem 1 %32 Samsung Galaxy Note 4 Antenna Replacement: passo 4, imagem 2 %32 Samsung Galaxy Note 4 Antenna Replacement: passo 4, imagem 3 %32
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  5. Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: passo 5, imagem 1 %32 Samsung Galaxy Note 4 Antenna Replacement, Detaching Antenna Connectors: passo 5, imagem 2 %32
    • Pull up on the connectors with tweezers to detach them from the phone.
    • The blue dot on the shorter connector belongs nearest the bottom of the phone.
Conclusão
19 outras pessoas executaram este guia.
Derek Nola
Membro desde: 01/06/15
2.244 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 70-6, Forte Winter 2015 Membro de Cal Poly, Team 70-6, Forte Winter 2015
CPSU-FORTE-W15S70G6
Membros da 4
Autoria de 16 guias
6 comentários
hi where can i buy an antenna connector ?
i live in india.
ramumohan007 - Responder
Google kar le
ravi raj -
I broke the actual ports that the antenna cables connect to on the mother board. Is thereally away to fix them or do I have to replace the whole logic/motherboard? I would like to keep my logic/motherboard because I don't want to lose all my text messages. What should I do?
shanonsmitt16 - Responder
I also broke the connector component on the motherboard. It remains attached to the blue cable. Could this be re-soldered?
Leanahtan Eiddiwnid - Responder
Is there a make shift way to put a extra antenna using one the two antenna ports above and to the left of the standard antenna cable. Without make any holes on the housing its self
Pedro A Sosa - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 30
Duração total: 23,293
