Pular para o conteúdo principal
  1. Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Slide your fingernail or plastic opening tool along the edge of the rear case. Lift the case gently from the base.
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - Responder
  3. Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base. Lift the battery out of its recess.
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Place your fingernail in the groove of the stylus pen.
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Remove the twelve 4mm Phillips #00 screws from the back chassis.
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Insert the plastic opening tool into the Stylus Pen placement holder.
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Remove the single screw beside headphone jack. Remove the single screw beside headphone jack.
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - Responder
  8. Use tweezers to remove both antenna clips. Use a spudger to disconnect six cable connectors.
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Pull up on the motherboard with tweezers.
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - Responder
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - Responder
    My wifi hotspot is not working
    Kiran Thopate - Responder
Conclusão
67 outras pessoas concluíram este guia.
Brittany Gail
Membro desde: 23-09-2014
8.194 reputação
8 Guias de autoria
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2014 Membro de USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Membros
25 Guias de autoria
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - Responder
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - Responder
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet -
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 57
Últimos 30 dias: 222
Todo: 45,779
