Ir para o conteúdo principal
Samsung Galaxy Note 3 Display Assembly Replacement
O que você precisa
  1. Samsung Galaxy Note 3 Display Assembly Replacement, Remove the rear case: passo 1, imagem 1 %32
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: passo 2, imagem 1 %32 Samsung Galaxy Note 3 Display Assembly Replacement, Remove Case from the Base: passo 2, imagem 2 %32
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Why... is it not simple enough already lol
    Adam Ahmed - Responder
  3. Samsung Galaxy Note 3 Display Assembly Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Note 3 Display Assembly Replacement, Battery: passo 3, imagem 2 %32
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Display Assembly Replacement, S Pen: passo 4, imagem 1 %32
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Display Assembly Replacement, Unscrew Back Chassis: passo 5, imagem 1 %32
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Back Chassis: passo 6, imagem 1 %32
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: passo 7, imagem 1 %32 Samsung Galaxy Note 3 Display Assembly Replacement, Screw Removal: passo 7, imagem 2 %32
    • Remove the single screw beside headphone jack.
    You can skip this step, it is usseles as this screw doesn’t attach the mother board at all
    Oriol Felisart - Responder
  8. Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: passo 8, imagem 1 %32 Samsung Galaxy Note 3 Display Assembly Replacement, Unfasten Clips and Cable Connectors: passo 8, imagem 2 %32
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Display Assembly Replacement, Motherboard Removal: passo 9, imagem 1 %32
    • Pull up on the motherboard with tweezers.
    Can i change at&t board to 9002 or 9005??,
    Ayyaz - Responder
    My mother board is not working what should I do I can't use Bluetooth, WiFi,hotspot or insert sim
    soha Javed - Responder
    My wifi hotspot is not working
    Kiran Thopate - Responder
  10. Samsung Galaxy Note 3 Display Assembly Replacement, Spudger Tool Placement: passo 10, imagem 1 %32
    • Insert the spudger into the headphone jack.
  11. Samsung Galaxy Note 3 Display Assembly Replacement, Lift to Separate Headphone Jack: passo 11, imagem 1 %32
    • Lift the spudger to separate the jack assembly from the motherboard.
    • Pull to remove.
    it remove the jack and the speaker in the same time.
    bangahome - Responder
  12. Samsung Galaxy Note 3 Display Assembly Replacement, Metal Bracket Removal: passo 12, imagem 1 %32
    • Remove the metal bracket located in the top left hand corner.
    As well as the front camera and sensor up under it.
    Xavier Rodriguez - Responder
  13. Samsung Galaxy Note 3 Display Assembly Replacement, Remove Vibrating Motor: passo 13, imagem 1 %32
    • Remove the vibrating motor by pulling up on it carefully with the tweezers.
    toggle the motor on the left, cause you need to remove the start button with the motor in the same time.
    All is paste on the display assembly. Use a screw to pass under the elements, and unglue them.
  14. Samsung Galaxy Note 3 Display Assembly Replacement, USB Port Removal: passo 14, imagem 1 %32
    • Lift USB port from the front assembly using the tweezers.
    You need to pull up the USB port and all the blue card.
    Use a screw to pass under the card, beacause everything is paste on the display assembly.
    Be VERY careful with the board, or just leave it there.
    In some (I think all) devices, the board is GLUED with the display assembly.
    Maybe to stabilize the port (But they can use screws, right? D*mn nasty glue!).
    Salvator - Responder
  15. Samsung Galaxy Note 3 Display Assembly Replacement, Display Assembly: passo 15, imagem 1 %32
    • You are now left with the display assembly.
    Wonderful description.
    matha studio - Responder
    It tooks me about an hour to change the display.
    Thanks for this tutorial.
Conclusão
146 outras pessoas executaram este guia.
Brittany Gail
Membro desde: 09/23/14
8.504 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2014 Membro de USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
Membros da 4
Autoria de 25 guias
10 comentários
είναι απόλυτα κατανοητό.
chandr - Responder
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace the digitizer?
rob lang - Responder
to safely remove the LCD display from the front touch screen glass w/o damaging the LCD screen I advise you to invest in and familiarize yourself with an LCD Separator machine and all the accessories that go along with it. Also, search for the machine and watch the videos..
tkflenorl - Responder
sunil - Responder
Can you just replace the digitizer or is the digitizer glue down to good to the display where it might damage the LCD display when trying to replace touch
sunil - Responder
This tutorial is incomplete, for instance the 'vibrator motor' removal does not specifies that this also removes the power button, and the removal of the front camera and light sensor is omitted, and the fact that heating the usb port part is very helpful if not mandatory before lifting it. I followed the video tutorial here which is complete: Samsung Galaxy Note 3 Display Assembly Video Tutorial Replacement
Julien GENEST - Responder
How do I remove the screen/digitizer/front glass from the display assembly? I have a broken screen and need to install the replacement LCD/digitizer piece I bought, and need to install it into the display assembly before reassembling.
David H - Responder
How I can replace the wifi and bluetooth part in note?
mohanad - Responder
warning :
on the new part (display assembly) don’t forget to remove plastic protection on the radiator of cpu !!
Michel BERNARD - Responder
I have successfully replaced the display with a new display, at which point the power button wasn’t working properly because I didn’t install it properly - fixed that, and I have now noticed that the phone will charge with the back plate on, only, however if I screw the back plate in this stops it from charging. What am I doing wrong?
Jesse - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 71
Duração total: 122,299
