O que você precisa
This is the back of the device and where you willl begin to take it apart
It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
Use the plastic opening tools to pry along the indicated box.
Lift up the silver piece to reveal the rest of the back cover.
Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
Remove the back cover.
Unscrew the two 2 mm screws indicated by the red circles with the #00 Philips Screwdriver.
Starting with the black motherboard connector, remove the module indicated by the red box in the second picture.
Replace the microSD port with a similar model.
5 outras pessoas executaram este guia.
2 comentários
In this guide, you missed a step on removing the battery.
