Ir para o conteúdo principal
Samsung Galaxy Note 10.1 microSD Port Replacement
O que você precisa
  1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: passo 1, imagem 1 %32 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: passo 1, imagem 2 %32 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: passo 1, imagem 3 %32
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: passo 2, imagem 1 %32 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: passo 2, imagem 2 %32 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: passo 2, imagem 3 %32
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: passo 3, imagem 1 %32 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: passo 3, imagem 2 %32 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: passo 3, imagem 3 %32
    • Unscrew the two 2 mm screws indicated by the red circles with the #00 Philips Screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the red box in the second picture.
    • Replace the microSD port with a similar model.
Conclusão
5 outras pessoas executaram este guia.
Tyler Salomone
Membro desde: 09/22/14
1.020 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 3-7, Brown Fall 2014 Membro de USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
Membros da 3
Autoria de 9 guias
2 comentários
Be sure to include screw lengths to the nearest mm on all guides.
Dan Brown - Responder
In this guide, you missed a step on removing the battery.
John Peterson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 3,888
