Ir para o conteúdo principal
Samsung Galaxy Note 10.1 Rear Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: passo 1, imagem 1 %32 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: passo 1, imagem 2 %32 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: passo 1, imagem 3 %32
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: passo 2, imagem 1 %32 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: passo 2, imagem 2 %32 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: passo 2, imagem 3 %32
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: passo 3, imagem 1 %32 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: passo 3, imagem 2 %32 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: passo 3, imagem 3 %32
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
Conclusão
3 outras pessoas executaram este guia.
Bryan Fernandez
Membro desde: 09/22/14
241 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-7, Brown Fall 2014 Membro de USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,167
