Ir para o conteúdo principal
Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement
O que você precisa
  1. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: passo 1, imagem 1 %32 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: passo 1, imagem 2 %32 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: passo 1, imagem 3 %32
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: passo 2, imagem 1 %32 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: passo 2, imagem 2 %32 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: passo 2, imagem 3 %32
    • Remove the three 5mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: passo 3, imagem 1 %32 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: passo 3, imagem 2 %32 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: passo 3, imagem 3 %32
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the orange box in the second picture.
    • Replace the 3.5 mm auxiliary port with a similar model.
Conclusão
Gavin Tipker
Membro desde: 11/01/18
193 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G1, Harley Fall 2018 Membro de IUPUI, Team S3-G1, Harley Fall 2018
IUPUI-HARLEY-F18S3G1
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,025
